Application Branding: How Do I Change my App Domain?
Host your IoT App under a custom domain
David Sepúlveda avatar
Written by David Sepúlveda
Updated over 2 months ago
Ubidots licenses allows you to serve your IoT Application under a custom domain. A customized Ubidots App could look like this:
NOTE: Domain customization is only available in trial accounts or licenses starting at the Industrial tier with a White Label app.
To set the custom domain for your app follow the below steps:
Step 1: Go to your account at industrial.ubidots.com
Step 2: Head over to "apps" in the main navigation bar.
Step 3: Click the pencil button of the app you want to work on to edit it.
Step 4: Click on "domain" at the left-hand menu.
Step 5: Enter your domain in the “custom domain” field.
The final setup needed is on your domain provider's end. Once logged in to your domain provider account:
Step 6: Create a CNAME record pointing to the default app domain with the structure AppName.iot.ubidots.com
NOTE: Most Domain providers offer a description on how to add a CNAME record. Here are some examples:
Once all 6 steps are completed, you’ll see a green checkmark next to the Custom Domain.
