Plans & Billing: How to Add UbiFunctions to my Account
UbiFunctions module lets you process and transform data from 3rd party platforms, as well as creating your own API endpoint.
Written by David Sepúlveda
What is a Function?
A "Function" is a Node.js or Python code that executes in Ubidots cloud when an GET or POST HTTPS request is made to the a Function's URL:
To activate the UbiFunctions in your Ubidots account, simply follow these below 4 steps.
Activate UbiFunctions
Step 1: Select "My Profile" from the user dropdown located in the top-right of your Admin App.
Step 2: Select "Billing" from the left-hand navigation panel.
Step 3: Click on "Change plan" option, then select the "Professional" plan or above.
Step 4: Click "Update Plan" to save your upgrade and activate UbiFunctions.
UbiFunctions Billing
The UbiFunctions module includes a limited amount of executions, and is then charged on a per-usage basis:
  • Includes 1 thousand executions
  • Executions are timed-out after 10 seconds. If you wish to extend this time-out, please reach out to our support team.
  • If any execution surpasses 2 seconds; it is counted as 2 executions (or more, based on time length of the execution)
  • Executions are billed at increments of $5 per million executions.
