HTML Canvas Widget: Interacting with account data
Learn how to use the HTML Canvas widget to retrieve your account's data.
Written by David Sepúlveda
1. Introduction
The HTML canvas is a powerful widget that allows Ubidots developers to create specialized visualizations using Ubidots API REST. Users can interact with their account data and listen to the events made on the dashboard to make the widget respond as a default Ubidots widget would.
1.1. How does the HTML Canvas widget work?
The HTML Canvas widget works with the same HTML/CSS/JS you would code when creating a simple website. It also considers the case when you may need to use a 3rd library (e.g. jQuery), so you can add these by inserting an URL containing the library.
Using this guide and the HTML Canvas Widget you will be able to:
  • Securely retrieve your account's Token, Dashboard and Device information.
  • Listen to navigation bar buttons on the Dashboard side.
IMPORTANT NOTE: This article is intended for developers with foundational knowledge of HTML, JS and CSS.
2. Creating an HTML Canvas
Step 1:Click on the "+" button located at the upper right corner. A drawer menu with widget's options should open.
​Step 2:Click on HTML canvas. Drawer menu displays setup options.
​Step 3: Name your widget.
​Step 4: Click on "Open editor" button.
​Step 5: Enter your HTML, CSS and JS code in the respective tab.
​Step 6: Add libraries by entering its URL in the "3rd party libraries section".
​Step 7: Save the changes.
3. Ubidots HTML Canvas library
The Ubidots HTML Canvas Library serves as the link between the HTML Canvas Widget and the dashboard, allowing their interaction. Accessed through the Ubidots class, this library offers methods, events, and properties that enable data retrieval and dashboard configuration.
Events usage
Use each event as the code snippet below shows, replacing 'UbidotsEvent' with any of the events listed in the next section. Also, you'd have to accommodate the function's argument according to the event.
const ubidots = new Ubidots();
ubidots.on('UbidotsEvent', function(data){
//Some logic
Pro tip: If the Preload dashboard data features is enabled, it is not required to instantiate the Ubidots class since it already has.
4. Available events and properties
​Listening events
Event
Description
Result
receivedToken
Default account token
BBFF-XXXXXXXXXX
selectedDashboardDateRange
Actual selected date range in the dynamic dashboard (timestamp in milliseconds).
{"start":1637006467592,"end":1637095008866}
isRealTimeActive
This event is triggered every time the Real Time button in the Dashboard is clicked.
true or false
dashboardRefreshed
This event is activated when a user clicks the refresh button in the dashboard.
true
selectedDevices
Returns a list containing the ids of the selected devices in a dynamic dashboard
['device-1-id', 'device-2-id', ... ]
selectedDeviceObjects
Returns a list containing the device objects of the selected devices in a dynamic dashboard
[{"name": "device-name", "id": "device-id", "label": "device-label"}, ... ]
selectedDevice
[DEPRECATED] Use selectedDevices instead.
Returns the id of the currently selected device in a dynamic dashboard.
'device-1-id'
[DEPRECATED] Use electedDeviceObjects instead.
Returns the device object of the currently selected device in a dynamic dashboard.
selectedDashboardObject
Return the whole object of a Dashboard as received when loading the dashboard
{"id": "dashboard-id", "name": "dashboard-name", "organization_data": {"id": 25, "name": "My First Customer", "properties": {"color": "#00BCD4"}}, "timeframe": {"endDate": "now", "startDate": "now-24h"}}
ready
Returns an object with the information of all the other events. See example.
BBFF-XXXXX
{"start":1651761902036,"end":1651848302036}
5e8bb8644763e72e09658f76
Each of those events is related to a property within the Ubidots class that can be used to retrieve exactly the same data as an alternative to setting an event handler and waiting for the event:
Ubidots class property
Associated event
dashboardDateRange
dashboardObject
deviceObject[DEPRECATED]
selectedDeviceObject[DEPRECATED]
selectedDevice[DEPRECATED]
selectedDevices
selectedDevices
token
receivedToken
realTime
isRealTimeActive
Setter events:
Event
Description
Arguments
​setDashboardDevice
Ability to set the selected device in a Dynamic Dashboard
​device-id
​setDashboardDateRange
Ability to set the date and time range in a dashboard, dynamic or static.
{"endTime": "now", "startTime": "now-24h"}}
​setRealTime
Ability to turn on or off the dashboard real time update
​true or false
​refreshDashboard
Ability to refresh the dashboard data in all widget.
setFullScreen
Enable, Disable, or Toggle the Dashboard into Fullscreen
  • toggle : toggles the Fullscreen state of the Dashboard
  • enable : sets the Dashboard to Fullscreen
  • disable: takes the Dashboard out of Fullscreen.
5. Examples
5.1. Interacting with dashboard data​
The following example uses Ubidots' "listener events" on an HTML Canvas in order to extract information from Ubidots and display it on the dashboard:
HTML
<div>
<p id="token"></p>
<p id="dashboard"></p>
<p id="dateRange"></p>
<p id="deviceSelected"></p>
<p id="device"></p>
<p id="isRealTimeActive"></p>
<p id="dashboardRefreshed"></p>
<p id="eventToken"></p>
<p id="eventDashboard"></p>
<p id="dashboardDateRange"></p>
<p id="eventDeviceSelected"></p>
<p id="eventDevice"></p>
<p id="eventRefresh"></p>
<p id="eventisRealTimeActive"></p>
</div>
JavaScript
var ubidots = new Ubidots();
ubidots.on('receivedToken', function (data) {
document.getElementById('eventToken').innerText = "TOKEN: " + data;
ubidots.on('selectedDashboardObject', function (data) {
document.getElementById('eventDashboard').innerText = "Dashboard Object: " + JSON.stringify(data)
ubidots.on('selectedDashboardDateRange', function (data) {
document.getElementById('dashboardDateRange').innerText = "Dashboard date range: " + JSON.stringify(data);
ubidots.on('selectedDevices', function(data) {
let listOfIds = data.join(', ');
document.getElementById('eventDeviceSelected').innerText = "Selected Device ids: " + listOfIds;
ubidots.on('selectedDeviceObjects', function (data) {
let formattedData = JSON.stringify(data); // 2-space indentation
document.getElementById('eventDevice').innerText = "Device Object: \n" + formattedData;
ubidots.on('isRealTimeActive', function (data) {
document.getElementById('eventisRealTimeActive').innerText = "Real time button: " + JSON.stringify(data);
ubidots.on('dashboardRefreshed', function (data) {
document.getElementById('eventRefresh').innerText = "The Dashboard refresh button was pressed."
​IMPORTANT NOTE: There is no need to add any external library to use these methods and properties, Ubidots adds libraries to do this by default once you've created the HTML Canvas widget.
5.2. Set a device in a Dynamic Dashboard
HTML
<div class="set-device--container">
<p>Device set successfully</p>
<input type="text" placeholder="Enter Device id" class="set-device--input" id="device" />
<button type="button" class="set-device--button" id="send-value">Set device</button>
</div>
CSS
.set-device--container {
position: absolute;
top: 50%;
left: 50%;
transform: translate(-50%, -50%);
.set-device--input {
display: block;
margin: 0 auto;
border: none;
border-bottom: 2px solid #28AECD;
font-size: 14px;
outline: none;
.set-device--button {
background: #FFFFFF;
border: 2px solid #28AECD;
border-radius: 20px;
color: #28AECD;
font-size: 14px;
margin-top: 10px;
width: 100%;
.set-device--button:hover {
background: #28AECD;
color: #FFFFFF;
cursor: pointer;
.notification--container {
display: none;
JS
var $setDevice = $('#send-value');
var $notification = $('#notification');
$setDevice.on('click', function () {
var $device = $('#device'); // Ensuring declaration of the variable
ubidots.setDashboardDevice($device.val());
$notification.show();
3rd party library
https://cdnjs.cloudflare.com/ajax/libs/jquery/3.3.1/jquery.min.js
5.3. Turn on/off Dashboard Real Time
HTML
<div class="notification--container" id="notification">
<p>Dashboard Real Time</p>
</div>
<div class="real-time--container">
<button type="button" class="real-time--button" id="real-time">
Enable real time
</button>
</div>
CSS
.real-time--container {
position: absolute;
top: 50%;
left: 50%;
.real-time--button {
color: #28AECD;
font-size: 20px;
margin-top: 10px;
width: 100%;
.real-time--button:hover {
color: #FFFFFF;
cursor: pointer;
display: none;
JS​
var $realTime = $('#real-time');
$realTime.on('click', function () {
ubidots.setRealTime(true)
3rd party library
5.4. Activate Dashboard Refresh button from your HTML Canvas
HTML
<p>Dashboard successfully refreshed</p>
</div>
<div class="refresh-dashboard--container">
<button type="button" class="refresh-dashboard--button" id="refresh-dashboard">
Refresh Dashboard
</button>
</div>
CSS
.refresh-dashboard--container {
position: absolute;
top: 50%;
left: 50%;
.refresh-dashboard--button {
color: #28AECD;
font-size: 14px;
margin-top: 10px;
width: 100%;
.refresh-dashboard--button:hover {
color: #FFFFFF;
cursor: pointer;
display: none;
JS
var $refreshDashboard = $('#refresh-dashboard');
$refreshDashboard.on('click', function () {
ubidots.refreshDashboard()
3rd party library
