Create Table Widgets in Ubidots
Learn how to create Table Widgets with Ubidots Dashboards
Ubidots provides data visualization in multiple forms, one of the most popular is Table Widgets. Table widgets are composed of rows and columns, and are excellent for:
  • Comparing a wide set of values.
  • Showing, to each member of a diverse audience, their specific data.
  • Displaying different units of measure that might not otherwise be understood with a bar or pie chart.
  • Provide precision and data interpretation.
1. Create a Devices Table widget
After logging into your Ubidots account, select the appropriate Dashboard and follow the steps below to create a Devices Table widget that will display all the data related to multiple devices:
Step 1: Create a new widget: Click on the "+" icon at the top right corner to create a new widget.
Step 2: Select Devices table
Step 3: if your dashboard is dynamic and so the widget, choose in the Device list option the Devices you want to display in the table.
  • Set by Dashboard
  • All Devices
  • Device Group
  • Device Type
Step 4: Add Devices as rows
Step 5: Choose one of the following options to display as a column:
– Context data
 Enter the variable label and the context key.
 Select the Color behavior.
– Value
 Enter the variable label.
 Select an aggregation method and Span.
– Device property
 Enter the Device property key.
– Date
 Enter the variable label and column name.
Moving to the Appearance section:
Step 6: Set all the available fields:
Name your table widget
– Set the Decimal places
– Choose a Date format
– Select Borders and Border width.
– Select the number of Devices/Variables/Values per page.
– If any, enter a Custom Style for your widget
2. Create a Variables Table widget
Display the readings of a variable with the respective timestamp.
Step 1: Click on the top-right "+" button
Step 2: Select Variables table.
Step 3: Add a variable as a row
Step 4: Choose the column to display: Value, Context data or Device property.
Step 5: Set all the available fields:
Column Name
– Select the aggregation method or enter the context key or device property
– Select the Color behavior
Name of the Table
– Set a Date format
– Select Border and Border width
– Select variables per page
3. Create a Values Table widget
Values table provide a list of the most recent recorded readings.
Step 2: Select Values table.
Step 3: Add a context or value column
Step 4: Set all the available fields:
Column Name
– Display the Device name(optional)
Step 5: Edit actions when on click or double click a variable's value.
Set dashboard device: “Set” the Dynamic Dashboard device with the device to which the variable in question belongs.
Go to device: It takes you to the device view in a new tab, showing the device to which the variable in question belongs.
Go to variable: It takes you to the variable view in a new tab, showing the variable in question.
Go to dashboard: Opens a new tab with the Dashboard specified by the user.
Go to URL: Opens a new tab with the specified URL.
Name of the Table
– Set a Date format
For more information about Values Table and its possibility to display different types of data, please see Create a Values Table Widget in Ubidots
IMPORTANT NOTE: You can drag and drop the columns of the table to change their display order.
Other developers also found helpful...
