All CollectionsFAQs and Troubleshooting
Security: Is Ubidots Secure?
How Ubidots manages security and what are some best practices to keep your data safe.
David Sepúlveda avatar
Written by David Sepúlveda
Updated over 3 months ago
Ubidots is a streamlined platform designed for ease of use and quick deployment with security best practices built along the way. For added layers of security, we recommend using your own firmware while utilizing Ubidots libraries for reference.
Below you will find some of Ubidots API best practices and some preventative measures you can take to keep your data yours.
API Best Practices
  • HTTP with SSL Encryption
HTTPS involves the use of an SSL certificate —"SSL" stands for secure sockets layer—which creates a secure encrypted connection between our servers and your devices. HTTPS helps us guarantee confidentiality, authenticity, and integrity
To activate your SSL certificate, request it for free and Ubidots will reply within 48 hours updating you on the activation of HTTPS in your application. Click here to learn more about how to request your application's SSL certificate.
  • MQTT with TLS Encryption
Ubidots supports the MQTT protocol, a lightweight publish/subscribe messaging transport optimized for IoT that supports TLS encryption. TLS (Transport Layer Security) provides a secure communication channel between a client and a server. Just like SSL, TLS is a cryptographic protocol that uses a handshake mechanism to create a secure connection between the client and the server. After the handshake is completed, encrypted communication between client and server is established and no attacker could understand the content of the communication.
  • Token-based Authentication
Unlike traditional server-based authentication, where a username and password have to be sent in every request (constantly exposing them to potential attackers), token-based authentication assigns a signed token after the first request, which can then be used for subsequent requests. This is how the token-based authentication takes place:
  1. A client requests a security token using an API key.
  2. Our Application validates the API key.
  3. Our Application provides a signed token back to the client.
  4. The client stores that token and sends it along with every request.
  5. The server verifies the token and accepts requests.
  6. If the client doesn't use the token for more than 6 hours, then it will need to request a new token using the API key.
Token-based authentication has become the standard for web API and Ubidots has also adopted it as a best practice. The token, which is not a cookie, is sent on every request, and with no cookie being sent CSRF attacks can be prevented. We also support token revocation that allows you to invalidate a specific token from your account.
  • Token in the HTTP headers
Ubidots supports an alternative means for authentication, which is by specifying the token in the URL as a parameter in the form of "token=". We enabled this to help you build faster prototypes as some devices might require extra coding to set HTTP headers, making it simpler to just use the token in the URL.
However, when you go to production, keep in mind that we recommend sending the token in the HTTP headers, using the "X-Auth-Token" HTTP header field, rather than the "token=" query parameter as it provides an added level of security.
Although we utilize HTTPS to ensure that all requests are encrypted for network transport, there is a possibility that the plain-text URL, with the value of the token, might appear in the logs of HTTP servers that process the requests. Additionally, there are spyware exploits whereby certain browser extensions track and aggregate browsing behavior and sell that data to third parties. Again, the use of a token as a query parameter could lend itself to unintentional exposure of your token.
Data Protection
  • Working with Leading Cloud Providers
Ubidots' infrastructure is hosted on AWS' data center us-east-2 (US East, Ohio). Users can request a private deployment in a different data center or leading cloud provider under our Enterprise tiers.
Working with renowned cloud providers help us minimize the risk of outages given their focus on reliability and uptime. AWS supports 143 security standards and compliance certifications, including:
  • ISO 270001: a widely-adopted, global security standard outlining the requirements for information security management systems that provides a systematic approach to managing company and customer information based on periodic risk assessment.
  • SOC 1: The Service Organization Control (SOC) 1 report is a widely recognized auditing standard established by the American Institute of Certified Public Accountants (AICPA). It evaluates a service organization's internal controls relevant to financial reporting, ensuring they meet the requirements of clients and stakeholders.
  • Multi-AAA User Management
Authentication, authorization, and accounting (AAA) is a term used to describe a framework that successfully controls access to computer resources, enforces policies, audits usage, and provides the information necessary to bill for services.
An Ubidots license allows you to gain control over who can access your device data at different levels: apps, customers, and end users.
  • Apps Permissions: Set which organizations can access a specific app.
  • Organization Permissions: Set which devices, dashboards, and users belong to a specific organization and can access it.
  • User Permissions: Add users to organizations, set passwords, or revoke access when needed.
Ubidots has committed itself to be a safe place for your IoT development, exploration, and deployments. Using the best practices provided in this article and limiting access with Ubidots multi-AAA user management, you can ward off malicious intruders from your valuable insights.
