Introduction
Digital Image Processing is a fast growing software field, part-due to the increase of available Machine Learning techniques that developers can access with the cloud. Having the ability to process digital images with the cloud averts any requirement for dedicated hardware, ultimately making DIP the go-to form of image processing because it is not only the most versatile method over the cloud, but also the cheapest. One of the most common applications of DIP is pedestrian detection and counting, a useful metric for airports, train stations, retail stores, stadiums, public events, and museums.
Traditional off-the-shelf people counters are not only expensive, but the generated data is often tied to proprietary systems that limits your possibilities for data extraction and KPI optimization. Conversely, an embedded DIP using your own camera and SBC can not only save you time and money, but it will also give you the freedom to tailor your application to the KPIs most important to you and extract insights from the cloud that would otherwise not be possible.
Using the cloud to enable your DIP IoT application allows developers to enhance overall functionality of the DIP application. With increased capabilities in the form of visualizations, reporting, alerting, and cross-referencing outside data sources such as weather, live vendor pricing, or a business management systems gives developers the freedom they desire. Imagine a retailer or grocer with insights stating the number people passing near an ice-cream fridge, those who buy vs. do not, and the number of times door was opened vs. internal temperature of the fridge. From just these few data points a retailer can run correlation analysis to better understand and optimize its efficient product pricing and the fridge overall energy consumption.
To begin your digital image processing application, Ubidots has created the following People Counting System tutorial using OpenCV and Python to analyze number of people in a given area. Expand your applications beyond just people counting with the added resources of Ubidots IoT Development Platform. Here, you can see a real live people counting dashboard built with Ubidots.
In this article we will review how to implement a simple DIP overlay to create a People Counter using OpenCV and Ubidots. This example works best with any Linux based distribution and also in a Raspberry Pi, Orange Pi or similar embedded systems.*
*For additional integration inquires, reach out to Ubidots Support for ways you business can take advantage of this value adding technology.
Table of Contents:
1) Application Requirements
2) Coding - 8 sub-sections
3) Testing
4) Results
  • Any embedded Linux with a derived version of Ubuntu
  • Installed Python 3 or newer in your OS.
  • Installed OpenCV 3.0 or greater in your OS.  If you are using Ubuntu or its derivatives follow the official installing tutorial or run the command below
pip install opencv-contrib-python
  • Once you have installed properly Python 3 and OpenCV, check your configuration by running this small piece of code (simply write 'python' on your terminal):
import cv2
cv2.__version__
you should get a print screen with your OpenCV version:
  • Installed Numpy, you can follow the instructions from the official page or just run the command below:
pip install numpy
  • Installed imutils
pip install imutils
  • Installed requests
pip install requests
2) Coding
The whole routine for detection and sending data can be found here. For a better explanation of our coding, we will split the code into eight sections to better explain each aspect of the code for your better understanding.
Section 1:
from imutils.object_detection import non_max_suppression                     import numpy as np
import imutils
import cv2
import requests
import time
import argparse
URL_EDUCATIONAL = "http://things.ubidots.com"                     URL_INDUSTRIAL = "http://industrial.api.ubidots.com"                     INDUSTRIAL_USER = True  # Set this to False if you are an educational user   TOKEN = "...."  # Put here your Ubidots TOKEN
DEVICE = "detector"  # Device where will be stored the result               VARIABLE = "people"  # Variable where will be stored the result
# Opencv pre-trained SVM with HOG people features
HOGCV = cv2.HOGDescriptor()                     HOGCV.setSVMDetector(cv2.HOGDescriptor_getDefaultPeopleDetector())
In Section 1 we import the necessary libraries to implement the our detector, imutils is an useful library tool for DIP and will let us perform different transformations from our results, cv2 is our OpenCV Python wrapper, requests will let us send our data/results over HTTP to Ubidots, and argparse will let us read commands from our command terminal inside our script. IMPORTANT: Do not forget to update this code with your Ubidots Account TOKEN, and if you are an educational user, be sure to set the INDUSTRIAL_USER to False.
After the library is imported, we will initialize our Histogram Oriented Object descriptor. HOG, for short, this is one of the most popular techniques for object detection and has been implemented in several applications with successful results and, to our fortune, OpenCV has already implemented in an efficient way to combine the HOG algorithm with a support vector machine, or SVM, which is a classic machine learning technique for prediction purposes.
This declaration: cv2.HOGDescriptor_getDefaultPeopleDetector() calls to the pre-trained model for people detection of OpenCV and will feed our support vector machine feature evaluation function.
Section 2:
def detector(image):
    @image is a numpy array
    image = imutils.resize(image, width=min(400, image.shape[1]))
    clone = image.copy()
    (rects, weights) = HOGCV.detectMultiScale(image, winStride=(8, 8),
                                              padding=(32, 32), scale=1.05)
    # Applies non-max supression from imutils package to kick-off overlapped
    # boxes
    rects = np.array([[x, y, x + w, y + h] for (x, y, w, h) in rects])
    result = non_max_suppression(rects, probs=None, overlapThresh=0.65)
    return result
The detector() function is where the 'magic' happens, it receives an RGB image split into three color channels. To avoid performance issues we resize the image using imutils and then call the detectMultiScale()  method from our HOG object. The detect-multi-scale method then let's us analyze the image and know if a person exists using the classification result from our SVM. The parameters of this method are beyond the scope of this tutorial, but if you wish to know more refer to the official OpenCV docs or check out Adrian Rosebrock's great explanation
The HOG analysis will generate some capture-boxes (detected objects), but sometimes these boxes are overlapping causing false positives or detection errors. To bypass this confusions we will use the non-maxima suppression utility from the imutils library to remove the overlapping boxes - as displayed below:
*Pictures reproduced from https://www.pyimagesearch.com
Section 3:
def localDetect(image_path):
    result = []
    image = cv2.imread(image_path)
    if len(image) <= 0:
        print("[ERROR] could not read your local image")
        return result
    print("[INFO] Detecting people")
    result = detector(image)
    # shows the result
    for (xA, yA, xB, yB) in result:
        cv2.rectangle(image, (xA, yA), (xB, yB), (0, 255, 0), 2)
    cv2.imshow("result", image)
    cv2.waitKey(0)
    cv2.destroyAllWindows()
return (result, image)
Now, in this part of our code, we must define a function to read an image from a local file and detect any persons in it. To accomplish this, you will see that I have simply called the detector() function and added a simple loop to paint the round-boxes for the detector. It returns the number of detected boxes and the image with the painted detection. Then, just simply recreate the result in a new OS window.
Section 4:
def cameraDetect(token, device, variable, sample_time=5):
    cap = cv2.VideoCapture(0)
    init = time.time()
    # Allowed sample time for Ubidots is 1 dot/second
    if sample_time < 1:
        sample_time = 1
    while(True):
        # Capture frame-by-frame
        ret, frame = cap.read()
        frame = imutils.resize(frame, width=min(400, frame.shape[1]))
        result = detector(frame.copy())
        # shows the result
            cv2.rectangle(frame, (xA, yA), (xB, yB), (0, 255, 0), 2)
        cv2.imshow('frame', frame)
        # Sends results
        if time.time() - init >= sample_time:
            print("[INFO] Sending actual frame results")
            # Converts the image to base 64 and adds it to the context
            b64 = convert_to_base64(frame)
            context = {"image": b64}
            sendToUbidots(token, device, variable,
                          len(result), context=context)
            init = time.time()
        if cv2.waitKey(1) & 0xFF == ord('q'):
            break
    # When everything done, release the capture
    cap.release()
def convert_to_base64(image):
    image = imutils.resize(image, width=400)
    img_str = cv2.imencode('.png', image)[1].tostring()
    b64 = base64.b64encode(img_str)
    return b64.decode('utf-8')
Similar to the function of Section 3, this Section 4 function will call the detector() method and paint boxes and the image will be retrieved directly from the webcam using the VideoCapture() method from OpenCV. We have also modified the official OpenCV slightly to get images from the camera and send the results to an Ubidots account every "n" seconds (the sendToUbidots() function will be reviewed later in this tutorial). The function convert_to_base64() will convert your image to a base 64 string, this string is very important for watching our results in Ubidots using JavaScript code inside an HTML Canvas widget.
Section 5:
def detectPeople(args):
    image_path = args["image"]
    camera = True if str(args["camera"]) == 'true' else False
    # Routine to read local image
    if image_path != None and not camera:
        print("[INFO] Image path provided, attempting to read image")
        (result, image) = localDetect(image_path)
        print("[INFO] sending results")
        b64 = convert_to_base64(image)
        # Sends the result
        req = sendToUbidots(TOKEN, DEVICE, VARIABLE,
        if req.status_code >= 400:
            print("[ERROR] Could not send data to Ubidots")
            return req
    # Routine to read images from webcam
    if camera:
        print("[INFO] reading camera images")
        cameraDetect(TOKEN, DEVICE, VARIABLE)
This method is intended to get the arguments inserted through your terminal and trigger a routine that searches for people in a locally stored image file or through your webcam.
Section 6:
def buildPayload(variable, value, context):
    return {variable: {"value": value, "context": context}}
def sendToUbidots(token, device, variable, value, context={}, industrial=True):
    # Builds the endpoint
    url = URL_INDUSTRIAL if industrial else URL_EDUCATIONAL
    url = "{}/api/v1.6/devices/{}".format(url, device)
    payload = buildPayload(variable, value, context)
    headers = {"X-Auth-Token": token, "Content-Type": "application/json"}
    attempts = 0
    status = 400
        status = req.status_code
        attempts += 1
        time.sleep(1)
return req
These two functions of Section 6 are the highway for sending your results to Ubidots for understanding and visualizing your data. The first function def buildPayload builds the payload inside the request, while the second function def sendToUbidots receives your Ubidots parameters (TOKEN , the variable, and device labels) to store the results. Which in this case is the length of the detected round-boxes by OpenCV. Optionally, a context can also be sent to store the results as an base64 image so it can be retrieved later.
Section 7:
def argsParser():
    ap = argparse.ArgumentParser()
    ap.add_argument("-i", "--image", default=None,
                    help="path to image test file directory")
    ap.add_argument("-c", "--camera", default=False,
                    help="Set as true if you wish to use the camera")
    args = vars(ap.parse_args())
    return args
Now in Section 7, we are reaching the end of our code analysis. The function argsParser() simply parses and returns as a dictionary the arguments passed through your terminal to our script. There will be two arguments within the Parser:
  • image: The path to the image file inside your system
  • camera: A variable that if set to 'true' will call the cameraDetect() method.
Section 8:
def main():
    args = argsParser()
    detectPeople(args)
if __name__ == '__main__':
    main()
Section 8 and the final piece of our code is the main()  function which simply calls the arguments from the console and launches the specified routine.
Don't forget, the entire code can be pulled from the Github here.
3) Testing
Open your favorite processor text (sublime-text, notepad, nano, etc) and copy and paste the full code available here. Update the code with your specific Ubidots TOKEN and save your file as "peopleCounter.py."
With your code properly saved, let's test the next four random images selected from the Caltech Dataset and Pexels public dataset:
To analyze these images, first your must store the images on your laptop or PC and track the path to analyze the images.
python peopleCounter.py PATH_TO_IMAGE_FILE
In my case, I stored the images in a path labeled as 'dataset.' To execute a valid command, run the below command but with your image's path.
 python peopleCounter.py -i dataset/image_1.png
If you wish to take images from your camera instead of a local file, just simply run the command below:
python peopleCounter.py -c true
Test results:
In addition to these testing checks, you will also see, in real-time, the results of these tests stored in your Ubidots account:
4) Creating your Dashboard
We will use an HTML Canvas to watch in real time our results, this tutorial is not intended for HTML canvas widgets, so if you do not know how to use them please refer to the articles below:
We will use the basic real time example with minor modifications to watch our images. Below you can see the widget's code snippet
HTML
<img id="img" width="400px" height="auto"/>
JS
var socket;
var srv = "industrial.ubidots.com:443";
// var srv = "app.ubidots.com:443"  // Uncomment this line if you are an educational user
var VAR_ID = "5ab402dabbddbd3476d85967"; // Put here your var Id
var TOKEN = ""  // Put here your token
$( document ).ready(function() {
function renderImage(imageBase64){
  if (!imageBase64) return;
  $('#img').attr('src', 'data:image/png;base64, ' + imageBase64);
// Function to retrieve the last value, it runs only once
function getDataFromVariable(variable, token, callback) {
  var url = 'https://things.ubidots.com/api/v1.6/variables/' + variable + '/values';
  var headers = {
    'X-Auth-Token': token,
    'Content-Type': 'application/json'
  $.ajax({
    url: url,
    method: 'GET',
    headers: headers,
    data : {
      page_size: 1
    success: function (res) {
      if (res.results.length > 0){
      renderImage(res.results[0].context.image);
      callback();
// Implements the connection to the server
socket = io.connect("https://"+ srv, {path: '/notifications'});
var subscribedVars = [];
// Function to publish the variable ID
var subscribeVariable = function (variable, callback) {
  // Publishes the variable ID that wishes to listen
  socket.emit('rt/variables/id/last_value', {
    variable: variable
  // Listens for changes
  socket.on('rt/variables/' + variable + '/last_value', callback);
  subscribedVars.push(variable);
// Function to unsubscribed for listening
var unSubscribeVariable = function (variable) {
  socket.emit('unsub/rt/variables/id/last_value', {
    variable: variable
  var pst = subscribedVars.indexOf(variable);
  if (pst !== -1){
    subscribedVars.splice(pst, 1);
var connectSocket = function (){
  console.log("hola");
  // Implements the socket connection
  socket.on('connect', function(){
    console.log('connect');
    socket.emit('authentication', {token: TOKEN});
  window.addEventListener('online', function () {
    console.log('online');
  socket.on('authenticated', function () {
    console.log('authenticated');
    subscribedVars.forEach(function (variable_id) {
      socket.emit('rt/variables/id/last_value', { variable: variable_id });
/* Main Routine */
getDataFromVariable(VAR_ID, TOKEN, function(){
  connectSocket();
connectSocket();
//connectSocket();
// Subscribe Variable with your own code.
subscribeVariable(VAR_ID, function(value){
  var parsedValue = JSON.parse(value);
  console.log(parsedValue);
  //$('#img').attr('src', 'data:image/png;base64, ' + parsedValue.context.image);
  renderImage(parsedValue.context.image);
Do not forget to put your account TOKEN and the variable ID at the beginning of the code snippet.
THIRD PARTY LIBRARIES
Add the next third party libraries:
Once you save your widget, you should get something like the one below:
4) Results
You can watch the dashboards with the results in this link
In this article we have explored how to create an IoT People Counter using DIP (image processing), OpenCV, and Ubidots. With these services, your DIP application is far more accurate than PIR or other optical sensors when detecting and identifying the differences between people, places, or things – giving you an efficient people counter without all the static of early data manipulation.
Let us know what you think by leaving Ubidots a comment in our community forums or connect with Ubidots simply with Facebook, Twitter or Hackster.
Recommended articles:
Happy Hacking!
