LabVIEW and Ubidots Example
Integrate the power of LabVIEW and Ubidots
Who doesn't love LabVIEW? it's nice visual programming language makes it easy to solve complex engineering problems fast.
In this tutorial we’ll explain:
  1. How to send values from LabVIEW.
  2. How to read values from LabVIEW
Sending Values
We'll use a Sine wave simulator in LabVIEW and then send its data to Ubidots by making an HTTP Post request to this URL:
https://industrial.api.ubidots.com/api/v1.6/devices/{DEVICE_LABEL}/?token={YOUR-TOKEN}
In this case, the device label will be "labview", so the data will appear in Ubidots under a device named "labview":
You can change the name, but not the API label, since it is the unique ID used to identify the device in your account. Here's the source code image:
This is how the interface looks like:
Here's a link to the VI file. Finally, we can build a nice Ubidots dashboard with the incoming data:
Getting Values from Ubidots
This example will  read the last value of an Ubidots variable using this endpoint URL:
https://industrial.api.ubidots.com/api/v1.6/devices/{DEVICE_LABEL}/{VARIABLE_LABEL}/values?page_size=1&token={YOUR-TOKEN}
Where:
  • Device Label: The unique identifier of the device in your Ubidots account that contains the variable you wish to read. In our case "labview".
  • Variable Label: The unique identifier of the variable within the device. In our case "signal".
So our URL to make the GET request is:
https://industrial.api.ubidots.com/api/v1.6/devices/labview/signal/values?page_size=1&token={YOUR-TOKEN}
This is the actual interface:
You can find our GET Vi project here. This animation shows the successful reading of an Ubidots value inside LabVIEW. In this case, we're using a control widget to send a value to the "signal" variable, which is then read by LabVIEW to update the Gauge in our VI.
Hope you enjoy these examples!
