Connect a LinkIt ONE to Ubidots using Wi-Fi over HTTP
Learn to setup and connect the popular LinkIt ONE board with Ubidots.
Updated over a year ago
The LinkIt ONE development board is an open source board for prototyping IoT projects. We really liked the fact that it already includes built-in connectivity like GSM, GPRS, Wi-Fi, Bluetooth and GPS!
By following this guide you will be able to POST data to Ubidots using the LinkIt One module in just a couple of minutes!
  1. Setting up Arduino IDE
  2. Sending (POST) data to Ubidots
  3. Receiving (GET) data from Ubidots
  4. Summary
1. To be able to work with the LinkIt One  in the Arduino IDE, install the MediaTek platform using the preconfigured Arduino Board Manager. If you are not familiar with adding a board with the Arduino IDE, refer to this article for additional guidance.
2. With the MediaTek platform installed, select the LinkItOne device you are working with. In the case, we are working with a “LinkIt One”. To select your board from the Arduino IDE, select Tools > Board “LinkIt One”
With the following sample code you will be able to post the reading taken from the A0 of the LinkIt One board.
1. To post your first value in Ubidots, open the Arduino IDE and paste the sample code below. Once you have pasted the code, assign your unique Ubidots TOKEN, SSID (WiFi Name), and the Password of the available network.
   Ubidots WiFi client
   This sketch reads an analog input and sends this value to Ubidots
   Change the macro WIFI_AP, WIFI_PASSWORD, WIFI_AUTH, URL, TOKEN and VARIABLE_ID accordingly.
   based on the Web Client example created 13 July 2010
   by dlf (Metodo2 srl)
   modified 31 May 2012
   by Tom Igoe
   modified 20 Aug 2014
   by MediaTek Inc.
   modified 2 Sep 2015
   by Ubidots, Inc.
   modified 6 Oct 2016
   by Ubidots, Inc.
  #include <LTask.h>
  #include <LWiFi.h>
  #include <LWiFiClient.h>
  #define WIFI_AP "MTK Hackathon"
  #define WIFI_PASSWORD ""
  #define WIFI_AUTH LWIFI_OPEN  // choose from LWIFI_OPEN, LWIFI_WPA, or LWIFI_WEP.
  // Ubidots information
  #define URL    "industrial.api.ubidots.com"
  #define TOKEN  "Sxxxxxxxxx9m4wX"          // replace with your Ubidots token generated in your profile tab
  #define LABEL "linkit-one"                // your device label
  void setup()
    LTask.begin();
    LWiFi.begin();
    Serial.begin(19200);
    // keep retrying until connected to AP
    Serial.println("Connecting to AP");
    while (0 == LWiFi.connect(WIFI_AP, LWiFiLoginInfo(WIFI_AUTH, WIFI_PASSWORD)))
  boolean wifi_status(LWifiStatus ws){
    switch(ws){
      case LWIFI_STATUS_DISABLED:
        return false;
      break;
      case LWIFI_STATUS_DISCONNECTED:
        return false;
      break;
      case LWIFI_STATUS_CONNECTED:
        return true;
      break;
    return false;
  void loop()
    Serial.println("Connecting to Ubidots...");
    LWiFiClient c;
    while (!c.connect(URL, 80))
      Serial.println("Retrying to connect...");
      delay(100);
    Serial.println("Connected!");
    while(1){
      LWifiStatus ws = LWiFi.status();
      boolean status = wifi_status(ws);
      if(!status){
          delay(500);
      String payload = "{\"temp\":"+ String(analogRead(A0)) + "}";
      String le = String(payload.length());
      if(!c.connected()){
        while (!c.connect(URL, 80)){
          delay(100);
        Serial.println("Client reconnected!");
      // Build HTTP POST request
      c.print(F("POST /api/v1.6/devices/"));
      c.print(LABEL);
      c.println(F(" HTTP/1.1"));
      c.println(F("User-Agent: LinKit One/1.0"));
      c.print(F("X-Auth-Token: "));
      c.println(TOKEN);
      c.println(F("Connection: close"));
      c.println(F("Content-Type: application/json"));
      c.print(F("Content-Length: "));
      c.println(le);
      c.print(F("Host: "));
      c.println(URL);
      c.println();
      c.println(payload);
      c.println();
      int v;
      while(c.available()){
        v = c.read();
        if(v < 0){
          Serial.println("No response.");
          break;
        // Serial.print((char)v);  // Add this line to the code in test case
3. Upload the code into your “LinkIt One”. To do this, choose the "right-arrow" icon beside the "check mark" icon.
NOTE: If no response is seen, try unplugging the LinkIt One and then plugging it again. Make sure the baud rate of the Serial monitor is set to the same one specified in your code 19200.
5. Confirm the data in Ubidots. Now you should see the posted data in your Ubidots account, located the device called "linkit-one".
With the following sample code you will be able to subscribe a value from Ubidots to start controlling any asset you desire.
1. To begin receiving values from Ubidots, open the Arduino IDE and paste the sample code below. Once you have pasted the code, be sure to assign the following parameters:
  Ubidots WiFi client
  by Tom Igoe
  by MediaTek Inc.
  modified 2 Sep 2015
  by Ubidots, Inc.
#include <LTask.h>
#include <LWiFi.h>
#define WIFI_AP "xxxxxxx"
#define WIFI_PASSWORD "xxxxxxx"
#define TOKEN  "BBFF-xxxxxxxxx"          // replace with your Ubidots token generated in your profile tab
#define VAR_LABEL "temperature"
#define DEVICE_LABEL "maka-test"
//Variables for String response;
int value_index;
String value_string;
String value;
void setup()
  LTask.begin();
  LWiFi.begin();
  Serial.begin(9600);
boolean wifi_status(LWifiStatus ws) {
  switch (ws) {
      return false;
      break;
      return false;
      break;
      return true;
      break;
  return false;
float get_value(char* variable_label) {
  LWiFiClient c;
  if (c.connect(URL, 80)) {
    Serial.println("Connected to Ubidots");
    String response = "";
    // Build HTTP GET request
    c.print(F("GET /api/v1.6/devices/"));
    c.print(DEVICE_LABEL);
    c.print(F("/"));
    c.print(variable_label);
    c.print(F("/values/?page_size=1&token="));
    c.print(TOKEN);
    c.println(URL);
    c.println();
    int count = 0;
    while (!c.available()  && count < 10000) {
      count++;
      delay(1);
    int v;
    while (c.available()) {
      v = c.read();
      if (v < 0) {
        break;
      Serial.println((char)v);
      response.concat((char)v);
    Serial.println("Printing response:");
    value_index = response.indexOf("\"value\": ");
    value_string = response.substring(value_index);
    value = value_string.substring(9, value_string.indexOf(","));
    Serial.println(value);
    return atof(value.c_str());
  else {
    Serial.println("Couldn't connect to Ubidots");
    return -1;
void check_wifi() {
  if (!status) {
    while (0 == LWiFi.connect(WIFI_AP, LWiFiLoginInfo(WIFI_AUTH, WIFI_PASSWORD))) {
      delay(500);
void loop()
  check_wifi();
  char* variable_label = VAR_LABEL;
  float last_value = get_value(variable_label);
  Serial.print("The value received is: ");
  Serial.println(last_value);
NOTE: If no response is seen, try unplugging the Linkit One and then plugging it again. Make sure the baud rate of the Serial monitor is set to the same one specified in your code 9600.
4. Summary
With this simple tutorial you are able to POST & GET data to/from Ubidots with the ease of the Arduino IDE and an LinkIt One. If you desire to handle context or timestamp values in your request checkout Ubidots REST API and modify the request built in the sample code provided.
