Connect your Devices
Connect an Arduino Yún to Ubidots over TCP/UDP
Learn how to setup the Arduino Yún with Ubidots to POST or GET data to/from Ubidots platform.
The Arduino Yun is a microcontroller board with the traditional Arduino chip (ATmega32u4) and an Atheros AR9331 that runs a Linux distro based on OpenWrt. The Ubidots-Arduino-YUN is an Arduino library available to help connect and interacting with sensor data using Ubidots IoT Application Development and Deployment Platform.
IMPORTANT NOTE: During the tests of this sample library we noticed that due to the hardware architecture the library presents inconsistencies making a POST and a GET request inside the same code. If you find the solution to this inconsistency, we invite you to make the Pull Request for our review.
Requiremets
NOTE: Ubidots puts time and resources to make this open source library work. However, we can’t be responsible for its stability since it runs on third-party products. Please contact the hardware manufacturer directly for any device-related inquiries.
 1. Setting up the Arduino IDE
4. Summary
This guide assumes your Yun is connected to a WiFi network with Internet access. If not there yet, check Arduino’s guide to configure Yun’s WiFi connectivity.
1. Download the Ubidots Arduino YUN Library and install it. For a detailed explanation of how to install libraries using the Arduino IDE, refer to this guide
With the following sample code you will be able to post the ANALOG readings taken from Arduino YUN Board analog port.
1. To post your first dot to Ubidots from the hardware, open the Arduino IDE and paste the sample code below. Once you have pasted the code, you will need to assign your unique Ubidots TOKEN where indicated in the sample code.
// This example is to save a variable to the Ubidots API
#include <UbidotsYUN.h>
#define TOKEN "YOUR_TOKEN_HERE"
#define VARIABLE_LABEL "temperature"  // Change for your variable label desired
Ubidots client(TOKEN);
  client.init();
  Serial.begin(9600);
  float value = analogRead(A0);
  client.add(VARIABLE_LABEL, value); // Change for your variable name
  client.sendAll();
3. Upload the code into your Arduino YUN. To do this, choose the "right-arrow" icon beside the "check mark" icon.
4. To verify the connectivity of the device and that data is being sent, open the serial monitor by selecting the "magnifying glass" icon in the top right corner of the Arduino IDE to see the connectivity logs.
5. Confirm your data in Ubidots. Return to your Ubidots account to see the posted data in your Ubidots account, automatically having created a new device, called "yun," and any variables located the device.
With the following sample code you will be able to get a value from Ubidots to start controlling any asset you desire with your hardware.
// This example is to obtain a variable value from Ubidots
#define DEVICE_LABEL "device_label_here" // Assign the device containing the variable you want to GET
#define VARIABLE_LABEL "variable_label_here" // Assign the variable you want to GET
  client.init();
  Serial.begin(9600);
  Serial.print("the value obtained is: ");
  Serial.println(value);
  /* Print value with 5 decimal points precision */
  //Serial.println(value, 5);
  delay(5000);
3. To verify the connectivity of the device and that the data is being received, open the serial monitor by selecting the "magnifying glass" icon in the top right corner of the Arduino IDE to see the connectivity logs.
4. At this point, you should be able to see the last value received in Ubidots of the variable specified in the sample code above.
4. Summary
With this simple tutorial we are able to POST & GET data to/from Ubidots with the ease of the Arduino IDE and an Arduino YUN. If your wish to find more examples to handle context or timestamp values in your request checkout Ubidots documentation with the Arduino YUN by clicking here
