Connect a NodeMCU ESP8266 to Ubidots over MQTT
Learn to connect the NodeMCU ESP8266 to Ubidots Application Development Platform over MQTT.
Updated over 8 months ago
The NodeMCU Development Kit is based on the ESP8266, and integrates GPIO, PWM, IIC, 1-Wire and ADC into one board.
By following this guide you will be able to PUBLISH and SUBSCRIBE data to/from Ubidots using the NodeMCU ESP8266 module in just a couple of minutes!
1. Setting up the Arduino IDE
1. To be able to work with the NodeMCU ESP8266 platform in the Arduino IDE, you will need to install the ESP8266 platform using the preconfigured Arduino Board Manager. If you are not familiar with adding a board with the Arduino IDE, refer to this article for additional guidance.
NOTE: When installing the ESP8266 platform in your Arduino IDE, please make sure to install version 3.1.2
2. With the ESP8266 platform installed, select the ESP8266 device you are working with. In the case, we are working with a “NodeMCU 1.0(ESP12E module)”. To select your board from the Arduino IDE, select Tools > Board NodeMCU 1.0(ESP12E module)”.
3. Download and install the UbidotsMQTTESP8266 library. For a detailed explanation of how to install libraries using the Arduino IDE, refer to this guide.
2. Sending (PUBLISH) Data to Ubidots
With the following sample code you will be able to post the readings taken from ANALOG pin A0 of the NodeMCU ESP8266.
1. To publish your first value in Ubidots, open the Arduino IDE and paste the sample code below. Once you have pasted the code, you will need to assign your unique Ubidots TOKEN, SSID (WiFi Name) and Password of the available network.
#include "UbidotsESPMQTT.h"
#define TOKEN "....." // Your Ubidots TOKEN
#define WIFIPASS "....." // Your Wifi Pass
Ubidots client(TOKEN);
  Serial.print(topic);
  Serial.print("] ");
  for (int i=0;i<length;i++) {
  Serial.println();
  //client.ubidotsSetBroker("industrial.api.ubidots.com"); // Sets the broker properly for the industrial account
  client.setDebug(true); // Pass a true or false bool value to activate debug messages
  client.begin(callback);
  if(!client.connected()){
      client.reconnect();
  client.add("temperature", value1);
  client.ubidotsPublish("my-new-device");
  client.loop();
delay(5000);
3. Upload the code into your “NodeMCU 1.0(ESP12E module)”. To do this, choose the "right-arrow" icon beside the "check mark" icon.
NOTE: If no response is seen, try unplugging the NodeMCU and then plugging it again. Make sure the baud rate of the Serial monitor is set to the same one specified in your code 115200.
5. Confirm your data in Ubidots. Now you should see the posted data in your Ubidots account, located the device called "my-new-device".
NOTE: To change the name ID of the device being updated in Ubidots, replace the string assigned in code with the following line:
3. Receiving (SUBSCRIBE) Data from Ubidots
With the following sample code you will be able to subscribe a value from Ubidots to start controlling any asset you desire.
1. To begin receiving values from Ubidots, open the Arduino IDE and paste the sample code below. Once you have pasted the code, be sure to assign the following parameters:
  • Device Label of the device which contains the variable to want to GET.
  • Variable Label of the variable you want to GET.
#define WIFINAME "....." //Your SSID
#define DEVICE_LABEL  "..."  // Put here your Ubidots device label
#define VARIABLE_LABEL  "..."  // Put here your Ubidots variable label
  Serial.print("] ");
  Serial.println();
  client.ubidotsSetBroker("industrial.api.ubidots.com"); // Sets the broker properly for the Industrial account
  client.setDebug(false); // Pass a true or false bool value to activate debug messages
  client.ubidotsSubscribe(DEVICE_LABEL, VARIABLE_LABEL); //Insert the dataSource and Variable's Labels
      client.reconnect();
  client.loop();
2. Verify & Upload the code into the board following the same steps provided in the PUBLISH step above.
NOTE: If no response is seen, try unplugging the NodeMCU ESP8266 and then plugging it again. Make sure the baud rate of the Serial monitor is set to the same one specified in your code 115200.
4. Summary
With this simple tutorial you are able to PUBLISH & SUBSCRIBE data to/from Ubidots with the ease of the Arduino IDE and an NodeMCU ESP8266. If your wish to find more examples to handle context or timestamp values in your request checkout Ubidots documentation with the ESP8266 by clicking here.
