All CollectionsConnect your Devices
Connect an Arduino UNO + GPRS Shield to Ubidots over TCP/UDP
Learn to setup and connect the Arduino Uno board + GPRS Shield to POST and GET data over TCP/UDP to/from Ubidots.
Updated over 5 months ago
The GPRS Shield is based on the SIM900 module from SIMCOM. It is compatible with all boards that have the same form factor (and pinout) as a standard Arduino Board.
The GPRS Shield is configured and controlled via its UART using simple AT commands, is based on the SIM900 module from SIMCOM, and is about the size of a credit card.
By following this guide you will be able to POST and GET data to/from Ubidots using an Arduino UNO Board with a GPRS Shield in just a couple of minutes!
Step-By-Step
 1. Hardware Setup
2. Setting up the Arduino IDE
5. Summary
1. Hardware Setup
 1. Insert the SIM card with an activated data plan into the GPRS Shield.
2. Place the GPRS Shield atop of the Arduino UNO and apply gentle pressure until the shield's pins and the board's headers at tightly connected.
3. The library which is going to be used to send handle the data with Ubidots uses the digital PIN "JP" of the SIM900 (PIN 9 in the Arduino) to power on/off the GPRS shield. Make sure the JP pad is soldered. The pad of the JP pin can be found next to the ISP port of the GPRS board. For additional information in soldering the JP pad, click here.
  1. Download the Ubidots GPRS library and install it. For a detailed explanation of how to install libraries using the Arduino IDE, refer to this guide.
With the following sample code you will be able to post the ANALOG readings taken from Arduino UNO analog port.
NOTE: Before running the examples, make sure you have an active data plan. You will also need your mobile operator’s APN settings (APN, USERNAME, PASSWORD). You should be able to easily find these settings in Google or on your operator’s website.
1. To post your first value in Ubidots, open the Arduino IDE and paste the sample code below. Once you have pasted the code, you will need to assign your unique Ubidots TOKEN and the APN (Access Point Name) of your cellular provider with username and password.
// using TCP protocol.
#include <Ubidots.h>
// Your GPRS credentials, if any
const char *APN = "Put_the_APN_here";
const char *USER = "Put_the_APN_user_here";
const char *PASS = "Put_the_APN_pwd_here";
const char *TOKEN = "Put_your_Ubidots_token_here";
const char *DEVICE_LABEL = "Put_your_device_API_label";
const char *VARIABLE_LABEL = "Put_your_variable_API_label";
Ubidots client(TOKEN,APN,USER,PASS);
  client.setDebug(true); // Set true to make available debug messages }
  float value = analogRead(A0);  // Reading analog pin A0
  client.add(VARIABLE_LABEL, value);
  if(client.send()){
    Serial.println("Data sent to Ubidots sucessfully!")
  delay(5000);
3. Upload the code into your Arduino UNO + GPRS Shield. To do this, choose the "right-arrow" icon beside the "check mark" icon.
5. Confirm your data in Ubidots. Now you should see the posted data in your Ubidots account, located the device called "GPRS".
  • APN (Access Point Name) of your cellular provider with username and password
  • Device Label of the device which contain the variable desired to be obtained
  • Variable Label of the variable desired to be obtained
  client.setDebug(true);// Set true to make available debug messages
  float value = client.get(DEVICE_LABEL, VARIABLE_LABEL);
  if(value!=ERROR_VALUE){
    Serial.print("Getting variable value: ");
    Serial.println(value);
  delay(5000);
4. At this point, in the serial monitor, you should be able to see the last value of variable specified in the firmware that was received in Ubidots.
5. Summary
With this simple tutorial we are able to POST & GET data to/from Ubidots with the ease of the Arduino IDE and a Arduino UNO + GPRS Shield. If your wish to find more examples to handle context or timestamp values in your request checkout Ubidots documentation with the GPRS Shield by clicking here
