The Arduino Ethernet Shield is based on the Ethernet chip Wiznet W5100, which supports up to 4 socket connections simultaneously and is ideal for IoT solutions in the home, office, or reliable non-industrial applications.
Following this guide you will be able to POST and GET data to/from Ubidots using the Ethernet Shield connected to an Arduino UNO Board in just a couple of minutes!
 1. Hardware Setup
2. Setting up the Arduino IDE
5. Summary
 1. Hardware Setup
1. To begin, place the Ethernet Shield atop the Arduino UNO and apply gentle pressure to connect the shield's pins with the board's headers. Now with the Arduino Uno + Ethernet shield assembled you are able to connect to the internet via Ethernet wired connection.
2. To establish the connection with the network, plug one end of the Ethernet cable to the Ethernet Shield and the other one into the router or socket which provides network services.
1. Download the Ubidots Ethernet library and install it. For a detailed explanation of how to install libraries using the Arduino IDE, refer to this guide.
2. Before programming your Ethernet Shield it is important verify if the hardware is working properly. For this, we highly recommend making the sample test provided by Arduino. Go to Sketch -> Examples -> Ethernet and select the "WebClient" example.
To verify the test and confirm connectivity, Open the Serial using the "magnifying glass" icon located in the top-right of the IDE. If everything is working properly, you will receive a server response from Google.com with the Arduino page information.
With the following sample code you will be able to post the ANALOG readings taken from Arduino Board analog port A0.
1. To post your first value in Ubidots, open the Arduino IDE and paste the sample code below. Once you have pasted the code, you will need to assign your unique Ubidots TOKEN and the MAC Address of the Ethernet shield.
 * Libraries included
#include <Ethernet.h>
#include <SPI.h>
#include <UbidotsEthernet.h>
 * Constants and objects
/* Assigns the Ubidots parameters */
char const * TOKEN = "Assign_your_Ubidots_TOKEN_here"; // Assign your Ubidots TOKEN
char const * VARIABLE_LABEL_1 = "temperature"; // Assign the unique variable label to send the data
char const * VARIABLE_LABEL_2 = "humidity"; // Assign the unique variable label to send the data
char const * VARIABLE_LABEL_3 = "pressure"; // Assign the unique variable label to send the data
/* Enter a MAC address for your controller below */
/* Newer Ethernet shields have a MAC address printed on a sticker on the shield */
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
/* initialize the instance */
Ubidots client(TOKEN);
  Serial.begin(9600);
  //client.setDebug(true);// uncomment this line to visualize the debug message
  /* start the Ethernet connection */
  Serial.print(F("Starting ethernet..."));
  if (!Ethernet.begin(mac)) {
    Serial.println(F("failed"));
  } else {
    Serial.println(Ethernet.localIP());
  /* Give the Ethernet shield a second to initialize */
  delay(2000);
  Serial.println(F("Ready"));
  Ethernet.maintain();
  /* Sensors readings */
  float value_1 = analogRead(A0);
  float value_2 = analogRead(A1);
  float value_3 = analogRead(A2);
  /* Sending values to Ubidots */
  client.add(VARIABLE_LABEL_1, value_1);
  client.add(VARIABLE_LABEL_2, value_2);
  client.add(VARIABLE_LABEL_3, value_3);
  client.sendAll();
  delay(5000);
3. Upload the code into your Arduino UNO + Ethernet Shield. To do this, choose the "right-arrow" icon beside the "check mark" icon.
5. Confirm your data in Ubidots. Now you should see the posted data in your Ubidots account, located the device called "arduino-ethernet".
#include <SPI.h>
char const * DEVICE_LABEL = "Assign_device_label_here"; // Assign the unique device label
char const * VARIABLE_LABEL = "Assign_variable_label_here"; // Assign the unique variable label to get the last value
  Serial.begin(9600);
  } else {
  delay(2000);
  /* Getting the last value from a variable */
  /* Print the value obtained */
  Serial.print("the value received is:  ");
  Serial.println(value);
  delay(5000);
4.  In the serial monitor, you will be able to see the last value received in Ubidots of the variable specified in the firmware.
4. Summary
With this simple tutorial we are able to POST & GET data to/from Ubidots with the ease of the Arduino IDE and a Arduino UNO + Ethernet Shield. If your wish to find more examples to handle context or timestamp values in your request checkout Ubidots documentation with the Ethernet Shield by clicking here
