Particle devices are compact and easy-to-code hardware development kits that provide everything you need to build a connected project. They combine an ARM micro-controller, a communication chip (WiFi, GPRS or 3G) and a web IDE with tons of community examples and libraries.
This tutorial explains how to interact with Ubidots MQTT broker using Particle.
  • A Particle device
  • Micro USB cable
  • Particle SIM card with data plan (if using a Particle Electron)
Setup
1.- Setting up your Particle device:
If you are using a Particle Electron, please follow this steps to set up the Particle data plan. Particle Electron steps.
If you are using a Particle Core you have two ways to set it up:
If you are using a Particle Photon you have two ways to set it up:
2.- After claiming your Particle Device and setting up your Ubidots account, let’s go to Particle’s Web IDE.
In the Particle’s Web IDE create a new app and set the name.
Go to the library tab.
In contributed library write Ubidots and select the UBIDOTSMQTT library. Make sure to add the last version library (1.1.0)
Click on INCLUDE IN APP. And return to “MYAPP.ino
This library create by default new Device. The name of this device will be "Particle" by default, and his label will be you Particle Core ID.
Subscribe to a variable
To subscribe to a variable, you need to specify your device and variable lables as input arguments for the ubidotsSubscribe() function. The incoming value will be returned by the MQTT library in the payload variable, by default the subscribed function only gets the last value of the variable subscribed. Retain value feature is only available for core platform users.
#include "UbidotsMQTT.h"
#ifndef TOKEN
#define TOKEN "Your TOKEN"  // Add here your Ubidots TOKEN
#endif
    Serial.print(topic);
    Serial.print("] ");
    Serial.println("payload obtained from server:");
    for (int i=0;i<length;i++) {
        Serial.print((char)payload[i]); // prints the answer of the broker for debug purpose
    // Some stuff to make with the payload obtained
    Serial.println();
 * Instances
Ubidots client(TOKEN, callback);
    client.initialize();
    // Uncomment this line if you have an Ubidots account
    //client.ubidotsSetBroker("industrial.api.ubidots.com");
    if(client.isConnected()){
        // Insert as first parameter the device to subscribe and as second the variable label
        client.ubidotsSubscribe("device-to-subscribe", "water-level");
    if(!client.isConnected()){
        client.reconnect();
    // Client loop for publishing and to maintain the connection
    client.loop();
Publish values to a device
To publish values to Ubidots, you have to call first the add() function first for storing the values to send (max of 5 values per request), so insert as parameters for the add() function the variable label, the context and the timestamp (these last two are optionals):
#ifndef TOKEN
#endif
    Serial.print("] ");
    Serial.println();
 * Instances
        client.reconnect();
    // Publish routine, if the device and variables are not created they will be created
    float value = 1;
    Serial.println("Sending value");
    client.add("test-var-1", value); // Insert as first parameter your variable label
    client.add("test-var-2", value, "\"lat\":10.302, \"lng\":2.9384"); //Adds value with context
    client.add("test-var-3", value, NULL, 1492445109); // Adds value with custom timestamp
    client.ubidotsPublish("test-device"); // Insert your device label where the values will be stored in Ubidots
    client.loop();
