The fatbox G3 is a reliable and rugged certified industrial IoT Gateway designed in Australia & built in the USA by Amplified Enginering, allowing you to connect any industrial device to the cloud in just a few hours.
This gateway work under a Linux environment, which can be programmable if is desired, allows you cross-compile existing C codes tutorials, as well as Python & LUA functions libraries to execute data corrections and minimize network data to the cloud to deploy local automation. Using as LTE/3G as connectivity type for remote deployments, as well as Ethernet or WiFi for local deployments.
Thanks to all the features offered by the fatbox G3, plus the multiple industrial protocols supported such as MODBUS, TCP/RTU, CAN bus, Serial (RS485/232), BLE and Zigbee this gateway is suitable for collect industry 4.0 data, monitor and controls remote assets, local sensor data pre-processing, connect CAN bus devices to cloud, high bandwidth mobile connectivity and more. To get depth in details, refer the official documentation here
To learn how to integrate the fatbox G3 with Ubidots, check this quick start guide  and start building your end-to-end IoT solution to explore the opportunities of growth in the Industry 4.0.
