Once you've created a pie chart like the one below, you may want to add edits its display to your end-users preferences. For notes to create your first Pie Chart.
Please note that as of the writing of this article Ubidots Pie charts only reflect last value readings. Development to extend these boundaries is underway.
To customize you Pie Chart ranges and colors, select the sprocket icon in the upper right corner of the widget and this window will display:
Here you may establish your categories, ranges, and colors. Our examples displays categories as: Low, Medium, and High - each being separated by its respective color and range.
