Once you create a map widget in your Ubidots or Ubidots for Education account you can customize them very easily. Here is how:
First, go to Devices Management —> Dashboards, and choose the map widget you want to customize. Select the sprocket in the upper right to display Settings.
As seen in the image, we removed the auto zoom (unfilled bubble) and chose 3 as the new distance based on a 1-20 scale, 1 being distant and 20 being near.
