For additional organization and identification of your data, easily adjust the device or variable description.
First, go to Device Management -> Devices -> click the device you wish to work with.
Next, select the device or variable Description and enter your desired descriptors.
Variable description
You can do the same for your devices' variables. Select the variable to open the Description area found in the left pane:
