If you have already created a Heat map but need to make some adjustments to critique the visuals to make them more appropriate to your solution, click the "sprocket" icon in the upper right corner of the heat map widget to display its Settings. Here you can specify the hotspots of your map:
  • Map Radius: (min 1 - max 50)
  • Map Zoom: (min 1 - max 20)
  • Map Layer: Satellite, Roadmap, or Hybrid
By changing these settings you can toggle the display for more readable and appealing heat maps for your IoT solution.
