An event (or alert) is any action triggered when data fulfills or exceeds a design rule. For example, an email or SMS message can be sent anytime a sensor stops sending data or a temperature exceeds a maximum threshold.
Create an alert
To begin, we will tell Ubidots to send an alert via email when the variable called "Power" exceeds a predetermined 1,500 boundary.
To create an alert:
  • Select Events (from the Device Management dropdown).
  • Select Add Event
  • Select a device: Machine 1 (the name of our device)
  • Select a variable: Power
  • If the value is greater than 1,500, then send an email
Next, choose the format of your alert. In this case, we will use emails.
Alerts can be very helpful and with Ubidots you can customize who, when, why, and what will be said in any alert. You might be interested in sending this alert to your maintenance department, machinist, or a manufacturer for quality assurance.
Lastly, name this alert for simple identifying the next time it is needed.
Select "Finish" and you have now created an alert for the Power variable when it exceeds 1,500.
We also created an alert when Machine's 1 energy consumption is below 5000 and inserted the last value of the variable within the message.
Types of Text Message Alerts
SMS: SMS stands for Short Messaging Service and is a text-only messages with a limit of 160 characters per message.
Telegram: is an open source messaging app that allows you to send files in almost any format.
For a closer look at event and alert creation check out the below video tutorial:
