How to Create Metrics Widgets in Ubidots
After logging into your Ubidots for Education or Ubidots account, select the appropriate dashboard to be working in and click the "plus" icon in the top right to create a new widget.
Next, choose which of the available metrics you wish to display:
*Count refers to the number of data readings that the Ubidots' platform has received in a certain period of time.
Then, select the appropriate time span for you metric:
Finally, select the correct variable you wish to compute in your metric.
Here is one possible result for your metric: Power.
If you wish to adjust the color, font, or text of your widget, consult this help center article for additional details or Metric Widget settings.
