An essential part of the Internet of Things is having objects speak to each other wirelessly. Raspberry Pi's are a great way to do this because of the low cost of available Wifi dongles and the ease of setting them up.
In a previous tutorial we covered how to setup your Raspberry Pi WiFi by manipulating the /etc/network/interfaces file directly. While this approach is pretty straightforward, it has some disadvantages:
  • It doesn’t handle all types of encryptions (WPA, WPK, etc.)
  • If the connection drops, it won't be re-established automatically
  • It doesn’t provide a simple interface to manage the connection, making it hard to troubleshoot
Hardware Needed
In this tutorial we’ll setup wifi on Raspberry Pi using the TP-Link TL-WN725N usb wifi adapter.
Step 1
First of all, make sure the WiFi dongle is plugged in before booting up your Raspberry Pi. Once you’re prompted with the command line, install the wicd-curses:
sudo aptitude install wicd-curses
Step 2
Wicd is a well known package to manage wifi networks from any Linux computer. Once installed, you can execute it:
sudo wicd-curses
You will be welcomed with a screen showing the available wifi networks. If your network is not showing up, you can try hitting Shift+P and then in the “Wireless interfaces” section type wlan0.
Step 3
Press F10 and then Shift+R to refresh the connections and then select your network:
Check the box “Automatically connect to this network” and then select the encryption type. Type your WiFi password and press F10 and then Shift+C to connect. Once you’re connected, type Shift+Q to exit wicd-curses.
You should be all set! You can check your Internet connection by pinging any website:
What to do next?
What can you do with a wifi-enabled Raspberry Pi? actually a lot. In the Internet of Things (IoT) space, you could create projects like:
We hope you enjoyed this as much as we do! Let us know your comments or inquiries. If you already have a project in mind, click below to get started!
Content originally published in Ubidots Blog on May 6, 2014.
