The Adafruit CC3000 comes in two forms, a WiFi breakout board (the small one shown in the picture above) and an Arduino Shield (the bigger one shown in the picture above). This article uses the Arduino Shield, but the sample firmware provided is the same for each of the CC3000 modules.
Adafruit CC3000 WiFi shield has a built in TCP/IP stack that allows it to communicate with external servers like Ubidots very simply. For a detailed review of the CC3000 module please reference its official overview.
Following this guide you will be able to POST and GET data to/from Ubidots using the CC3000 WiFi Shield connected to an Arduino UNO Board in just a couple of minutes!
 1. Hardware Setup
2. Setting up the Arduino IDE
5. Summary
1. Hardware Setup
1. To begin, assemble your CC3000 shield using this Adafruit CC3000 Shield guide. Soldering is required if your shield is not already prepared.
2. With the shield assembled, place the CC3000 shield atop the Arduino UNO and apply gentle pressure to connect the shield's pins with the board's headers. Now with the Arduino Uno + CC3000 shield is able to connect to the internet over WiFi.
WARNING: Use the Arduino 1.6.4 version or newer with the CC3000, EXCEPT for the firmware update sketches in the library examples folder. Use 1.0.6 for those!
WARNING: Make sure your Arduino is powered by a 1 amp or higher rated external power supply when using with the CC3000! Powering an Arduino + CC3000 from a computer/laptop USB port will lead to unstable behavior and lockups because the USB port can't supply enough power. :(
1. Download the libraries required & install them :
NOTE: For a detailed explanation of how to install libraries using the Arduino IDE, refer to this guide.
With the following sample code you will be able to post the ANALOG readings taken from Arduino Board analog port.
1. To post your first value in Ubidots, open the Arduino IDE and paste the sample code below. Once you have pasted the code, you must assign your unique Ubidots TOKEN, SSID (WiFi Name) and Password of the available network.
 * Libraries included
#include <UbidotsCC3000.h>
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
 * Constants and objects
#define WLAN_SSID       "SSID_here"  // Your WiFi SSID, cannot be longer than 32 characters!
#define WLAN_PASS       "Your_pass_here"  // Replace it with your WiFi pass
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY   WLAN_SEC_WPA2
/* Assigns the Ubidots parameters */
#define TOKEN "Your_token_here"  // Replace it with your Ubidots token
#define VARIABLE_LABEL "temperature" // Assign the Ubidots variable label
/* initialize the instance */
Ubidots client(TOKEN);
  client.initialize();
  client.wifiConnection(WLAN_SSID, WLAN_PASS, WLAN_SECURITY);
  //client.setDeviceLabel("my-new-device"); // Uncomment this line to change the default device name
  //client.setDebug(true); // Uncomment this line to set DEBUG on
   /* Sensors readings */
  float value = analogRead(A0);
 /* Sending value to Ubidots */
  client.add(VARIABLE_LABEL,value);
  client.sendAll();
  delay(5000);
3. Upload the code into your Arduino UNO + CC3000 module. To do this, choose the "right-arrow" icon beside the "check mark" icon.
NOTE: If no response is seen, try unplugging your Arduino and then plugging it again. Make sure the baud rate of the Serial monitor is set to the same one specified in your code 115200.
5. Confirm your data in Ubidots. Now you should see the posted data in your Ubidots account, located the device called "arduino-cc3000".
  • Ubidots TOKEN
  • Device Label of the device which contains the variable to want to GET.
  • Variable Label of the variable you want to GET
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#define DEVICE_LABEL "Your_label_here" // Replace it with your Ubidots' device label
#define VARIABLE_LABEL "Your_label_here" // Replace it with your Ubidots' variable label
  /* Getting the last value from a variable */
  /* Print the value obtained */
  Serial.print("The value obtained is: ");
  Serial.println(value);
  delay(5000);
NOTE: If no response is seen, try unplugging your Arduino and then plugging it again. Make sure the baud rate of the Serial monitor is set to the same one specified in your code.
5. Summary
With this simple tutorial you are able to POST & GET data to/from Ubidots with the ease of the Arduino IDE and an Arduino UNO Board + CC3000 Module. If your wish to find more examples to handle context or timestamp values in your request checkout Ubidots documentation with the CC3000 by clicking here
