Connect your Devices
Connect an ESP8266 stand-alone to Ubidots over HTTP
Learn how to connect the ESP8266 chipset to Ubidots Application Development Platform over HTTP
The ESP8266 is a low-cost WiFi module built by Espressif Systems. Its popularity has been growing among the hardware community thanks to it’s nice features and stability, to the point that it can be easily programmed using your Arduino IDE.
By following this guide you will be able to POST and GET data to/from Ubidots using the ESP8266 as stand alone module in just a couple of minutes!
  1. Hardware Setup
  2. Setting up the Arduino IDE
  5. Summary
1. Hardware Setup
To be able to program the ESP8266 as stand alone module you will need any UART to USB device such as the UARTbee, or you can program the module through any Arduino board by setting the Arduino RST to GND
1. To begin, establish the connection between the device used to program the ESP8266 by following the table below. First, let's identify the pin out of the ESP8266 to avoid any future hardware issue.
IMPORTANT NOTE: If you are using an Arduino UNO to access the ESP8266 you will need to set Arduino RST to GND. Please be careful with the VCC of the ESP8266, it works only with a 3.3V supply.
  • FAQs and Troubleshooting
One of the most common errors with the ESP8266 is the espcom_sync_failed:
If you receive this error when the RST is not set to GND. To correct this error, please verify:
  1. if the jumper wire correctly connected and use the above Pinout table;
  2. confirm that the Arduino RST is set to GND;
  3. confirm that the board: Generic ESP8266 Module is selected in the Arduino IDE. For additional assistance selecting the board, see step 2 in the Setting up the Arduino IDE below.
1. To be able to work with the ESP8266 platform in the Arduino IDE, you will need to install the ESP8266 board using the preconfigured Arduino Board Manager. If you are not familiar with adding a board with the Arduino IDE, refer to this article for additional guidance.
2. With the ESP8266 platform installed, select the ESP8266 device you are working with. In the case, we are working with a “Generic ESP8266 Module”. To select your board from the Arduino IDE, select Tools > Board Generic ESP8266 Module”.
3. Download and install the Ubidots library. For a detailed explanation of how to install libraries using the Arduino IDE, refer to this guide.
With the following example, you will be able to simulate random readings taken from the ESP8266 to Ubidots
1. To begin posting values to Ubidots, open the Arduino IDE and paste the sample code below. Once you have pasted the code, be sure to assign the following parameters:
#include "Ubidots.h"
const char* UBIDOTS_TOKEN = "...";  // Put here your Ubidots TOKEN
  // ubidots.setDebug(true);  // Uncomment this line for printing debug messages
  float value1 = random(0, 9) * 10;
  float value2 = random(0, 9) * 100;
  float value3 = random(0, 9) * 1000;
  ubidots.add("Variable_Name_One", value1);  // Change for your variable name
  bool bufferSent = false;
  bufferSent = ubidots.send();  // Will send data to a device label that matches the device Id
  if (bufferSent) {
  delay(5000);
3. Upload the code into your “Generic ESP8266 Module”. To do this, choose the "right-arrow" icon beside the "check mark" icon.
NOTE: If no response is seen, try unplugging the UART to USB device and then plugging it again. Make sure the baud rate of the Serial monitor is set to the same one specified in your code 115200.
5. Confirm your data in Ubidots. Now you should see the posted data in your Ubidots account.
NOTE: The device and variable label should be defined in the following line of code:
ubidots.get("a020a6133e21", "variable_name_one")
Where the first argument defines the device's label, and the second argument the variable's label.
get(const char* device_label, const char* variable_label)
  • Sample code:
  // ubidots.setDebug(true); //Uncomment this line for printing debug messages
  float value = ubidots.get("a020a6133e21", "variable_name_one");
  if (value != ERROR_VALUE) {
    Serial.print("Value:");
    Serial.println(value);
  delay(5000);
NOTE: If no response is seen, try unplugging the NodeMCU and then plugging it again. Make sure the baud rate of the Serial monitor is set to the same one specified in your code 115200.
5. Summary
With this simple tutorial you are able to POST and GET data to/from Ubidots with the ease of the Arduino IDE and an ESP8266 as stand alone module. If your wish to find more examples to handle context or timestamp values in your request checkout Ubidots documentation with the ESP8266 by clicking here
