The WEMOS D1 Mini ESP8266 is a development board similar to Arduino and developed especially for cost effective Internet of Things applications and solutions. Also compatible with Espressif's ESP32, the WEMOS series is perfect for educational and hobby IoT projects. With a 32 bit architecture (more powerful than the Arduino Due) and Wi-Fi connectivity, you can choose between the Arduino and Lua languages for your application's development.
By following this guide you will be able to POST and GET data to/from Ubidots using the WEMOS D1 mini in just a couple of minutes!
Setting up Arduino IDE
Sending (POST) Data to Ubidots
Receiving (GET) Data from Ubidots
Summary
1. Setting up Arduino IDE
1. To begin working with the Wemos D1 mini ESP8266 platform in the Arduino IDE, you will need to install the ESP8266 board using the preconfigured Arduino Board Manager. If you are not familiar with adding a board with the Arduino IDE, refer to this article for additional guidance.
2. With the ESP8266 platform installed, select the ESP8266 device you are working with. In the case, we are working with a “WEMOS D1 min”. To select your board from the Arduino IDE, select Tools > Board “WEMOS D1 min”.
3. Download and install the Ubidots library. For a detailed explanation of how to install libraries using the Arduino IDE, refer to this guide.
With the following example, you will be able to simulate random readings taken from the WEMOS to Ubidots
1. To begin posting values to Ubidots, open the Arduino IDE and paste the sample code below. Once you have pasted the code, be sure to assign the following parameters:
SSID (WiFi Name) & Password of the available network connection.
#include "Ubidots.h"
const char* UBIDOTS_TOKEN = "..."; // Put here your Ubidots TOKEN
// ubidots.setDebug(true); // Uncomment this line for printing debug messages
float value1 = random(0, 9) * 10;
float value2 = random(0, 9) * 100;
float value3 = random(0, 9) * 1000;
ubidots.add("Variable_Name_One", value1); // Change for your variable name
bool bufferSent = false;
if (bufferSent) {
delay(5000);
3. Upload the code into your “WEMOS D1 mini”. To do this, choose the "right-arrow" icon beside the "check mark" icon.
NOTE: If no response is seen, try unplugging the WEMOS D1 mini device and then plugging it again. Make sure the baud rate of the Serial monitor is set to the same one specified in your code 115200
5. Confirm your data in Ubidots. Now you should see the posted data in your Ubidots account.
Device Label of the device which contains the variable to want to GET.
Variable Label of the variable you want to GET
NOTE: The device and variable label should be defined in the following line of code:
ubidots.get("a020a6133e21", "variable_name_one")
Where the first argument defines the device's label, and the second argument the variable's label.
get(const char* device_label, const char* variable_label)
Sample code:
// ubidots.setDebug(true); //Uncomment this line for printing debug messages
float value = ubidots.get("a020a6133e21", "variable_name_one");
if (value != ERROR_VALUE) {
Serial.print("Value:");
Serial.println(value);
delay(5000);
NOTE: If no response is seen, try unplugging the NodeMCU and then plugging it again. Make sure the baud rate of the Serial monitor is set to the same one specified in your code 115200.
4. Summary
With this simple tutorial you are able to POST and GET data to/from Ubidots with the ease of the Arduino IDE and an WEMOS D1 mini.
Now its time to create Ubidots Dashboards to visualize your data and deploy your IoT solution! Happy Hacking! :)
