The Autonomo is a compact Arduino-compatible board that uses the Atmel Cortex M0+ 32bit microcontroller. It was designed to be autonomously powered by a solar panel.
This guide explains how to send and receive data to/from Ubidots from the SODAQ Autonomo over WiFi using the RN171 chip, also known as WiFibee.
  1. Setting up Arduino IDE
  4. Summary
1. To be able to work with the SODAQ platform in the Arduino IDE, you will need to install the SODAQ platform using the preconfigured Arduino Board Manager. If you are not familiar with adding a board with the Arduino IDE, refer to this article for additional guidance.
The Board Manager URL for the SODAQ is:
 http://downloads.sodaq.net/package_sodaq_index.json
2. With the SODAQ platform installed, select the SODAQ device you are working with. In this tutorial, we are working with a “SODAQ Autonomo”. To select your board from the Arduino IDE, select Tools –> Board SODAQ Autonomo”.
3. Download the Ubidots SODAQ WiFiBee library and install it. For a detailed explanation of how to install libraries using the Arduino IDE, refer to this guide.
With the following sample code you will be able to post the readings taken from ANALOG pin A0 of the SODAQ Autonomo.
1. To POST your first value in Ubidots, open the Arduino IDE and paste the sample code below. Once you have pasted the code, you will need to assign your unique Ubidots TOKEN, SSID (WiFi Name) and Password of the available network
#include <SODAQWiFibee.h>
/* Change the AUTH according to your network settings
   If is open change to WIFLY_AUTH_OPEN
   If is WPA1 change to WIFLY_AUTH_WPA1
   If is WPA1_2 change to WIFLY_AUTH_WPA1
   If is WPA2 change to WIFLY_AUTH_WPA1
// To add space in RN171 you just put "$" instead of " "
#define SSID "xxxxxxxxxx"
#define KEY "xxxxxxxxxx"
#define AUTH WIFLY_AUTH_WPA2_PSK
#define TOKEN "xxxxxxxxxx"  // Replace it with your Ubidots token
Ubidots client(TOKEN);
    client.wifiConnection(SSID, KEY, AUTH);
    float value = analogRead(A0);
    client.add("Temperature", value);
    client.sendAll();
3. Upload the code into your “SODAQ Autonomo”. To do this, choose the "right-arrow" icon beside the "check mark" icon.
5. Confirm your data in Ubidots. Now you should see the posted data in your Ubidots account, located the device called "SODAQWiFly".
1. To start GETTING values from Ubidots, open the Arduino IDE and paste the sample code below. Once you have pasted the code, be sure to assign the following parameters:
#define SSID "xxxxxxxxx"
#define KEY "xxxxxxxxx"
#define TOKEN "xxxxxxxxx"  // Replace it with your Ubidots token
#define ID "xxxxxxxxx"
    float value = client.getValue(ID);
    Serial.print("The last value is: ");
    Serial.println(value);
4. Summary
With this simple tutorial we are able to POST & GET data to/from Ubidots with the ease of the Arduino IDE and a SODAQ Autonomo over WiFi.
Now its time to create Ubidots Dashboards to visualize your data and deploy your IoT solution!
