Connect your Devices
Connect a Particle Device to Ubidots over HTTP, TCP, or UDP
Learn to setup a Particle Device to Send/Retrieve data to/from Ubidots using the Ubidots Library with the Particle Build IDE.
S
Particle devices are compact and easy-to-code hardware development kits that provide everything you need to build cloud-connected projects. Particle combines an ARM micro-controller, a communication chip (WiFi, GPRS or 3G) and a web IDE with tons of community examples and libraries to make your development with Ubidots as simple and efficient as possible.
This tutorial explains how to interact with Ubidots REST API using Particle.
Table of Contents
  1. Device Software Setup
  2. Ubidots Library: HTTP, TCP and UDP protocols
  3. Send Values to Ubidots
  4. Send Values with Context
  5. Send Values with Timestamp
  6. Send Values with GPS coordinates
  7. Retrieve Values from Ubidots
    7.1. Retrieve multiple variable last Values over TCP
Step 1: Setup and claim your Particle Device:
– Particle Electron: Follow this steps to set up the Particle data plan. Particle Electron steps.
– Particle Photon: You can setup your Particle Photon either Using your smartphone or Connecting it to your computer over USB.
Step 2: Create New App
In the Particle Build Web IDE, create a new app. For additional details in how to "Create New App," simply click here and follow the simple 3 step process.
NOTE: We titled this guide's project "Myapp". Whichever name you select, you will need to refer to the same name throughout your project. Whenever you see "Myapp," know this is a reference to your Particle IDE application.
Step 3: Add Ubidots library to "Myapp" project:
  • Go to the Libraries option on the right side panel
  • Search "Ubidots"
  • Select Ubidots Library
    NOTE: Be aware not to choose UbidotsMQTT Library
  • Click on "INCLUDE IN PROJECT".
  • Select the project to include the library in. In this case "Myapp".
  • Click on "CONFIRM".
2. Ubidots Library: HTTP, TCP and UDP Protocols.
Ubidots' library for Particle devices is a light-weight firmware that utilizes in-code Instance Declaration and Protocol Selection with standard method invoking to either Send/Retrieve data to/from Ubidots.
For Example:
Instance Declaration and Protocol Selection:
  • HTTP: Ubidots ubidots(UBI_TOKEN, UBI_HTTP);
  • TCP: Ubidots ubidots(UBI_TOKEN, UBI_TCP);
  • UDP: Ubidots ubidots(UBI_TOKEN, UBI_UDP);
Using one of the instances and protocols above, your device is authenticated with Ubidots cloud using the UBI_TOKEN  (TOKENS) and select the method to communicate using one of the flags UBI_HTTP, UBI_TCP or UBI_UDP.
For additional information about Ubidots library for Particle devices refer to our GitHub repository.
In the below examples you'll find sample codes to integrate to Ubidots from Particle Devices through the mentioned protocols mentioned above.
Following the below steps you'll be able to send data to Ubidots through any of the protocol supported by the library: HTTP, TCP, or UDP.
Step 1: Copy and paste the below code in your "Myapp" project.
Step 2: Enter a valid TOKEN from your Ubidots account.
Step 3: Choose Protocol by comment/uncomment the appropriate instance.
Step 4: Uncomment line 36 if you want to see debug messages on the serial monitor.
Step 5: Change the variable labels on lines 43, 44, 45 as needed.
Step 6: Verify the code.
Step 7: Flash the code to your Particle devices.
Step 8: Check your Ubidots account.
// This example sends data to multiple variables to
// Ubidots API through HTTP, TCP or UDP protocol.
#include "Ubidots.h"
#ifndef TOKEN
#define TOKEN "Your_Token"  // Put here your Ubidots TOKEN
#endif
Ubidots ubidots(TOKEN, UBI_TCP); // Comment this line to use another protocol.
//Ubidots ubidots(TOKEN, UBI_HTTP); // Uncomment this line to use HTTP protocol.
//Ubidots ubidots(TOKEN, UBI_UDP); // Uncomment this line to use UDP protocol
  //ubidots.setDebug(true); // Uncomment this line to print debug messages.
  ubidots.add("Variable_Name_One", value1); // Change for your variable name.
  bool bufferSent = false;
  if(bufferSent){
  delay(5000);
Following the below steps you'll be able to send data with context to Ubidots using any of the protocol supported by the library: HTTP, TCP, or UDP.
Step 1: Copy and paste the below code on "Myapp" project.
Step 5: Change the variable labels on lines 52 as needed.
// This example sends data and context to a variable to
#ifndef TOKEN
#endif
//Ubidots ubidots(TOKEN, UBI_UDP); // Uncomment this line to use UDP protocol.
    //ubidots.setDebug(true); // Uncomment this line for printing debug messages.
    float value = analogRead(A0);
    /* Adds context key-value pairs */
    ubidots.addContext("weather-status", "sunny");
    ubidots.addContext("time", "11:40:56 pm");
    /* Reserves memory to store context array */
    char* context = (char *) malloc(sizeof(char) * 60);
    /* Builds the context with the key-value pairs to send to Ubidots */
    ubidots.getContext(context);
    ubidots.add("temperature", value, context);  // Change for your variable name
    if(bufferSent){
    free(context);
    delay(5000);
Following the below steps you'll be able to send data with timestamp to Ubidots through any of the protocol supported by the library: HTTP, TCP or UDP.
Step 5: Change the variable labels on lines 43 as needed.
// This example sends data along with timestamp in POSIX ms standard
// to a variable to Ubidots API through HTTP, TCP or UDP protocol.
#ifndef TOKEN
#endif
  unsigned long timestamp_seconds = Time.now();
  ubidots.add("temperature", value, NULL, timestamp_seconds);  // Change for your variable name
  if(bufferSent){
  delay(5000);
6. Send Values with GPS Coordinates
Following the below steps you'll be able to send data with GPS Coordinates as context to Ubidots through any of the protocol supported by the library: HTTP, TCP or UDP.
Step 5: Change the variable labels on lines 65 as needed.
// This example send data with hardcoded GPS Coordinates
#ifndef TOKEN
#endif
  //ubidots.setDebug(true); //Uncomment this line for printing debug messages
  /* Harcoded Coordinates */
  float latitude = 37.773;
  float longitude = -6.2345;
  /* Reserves memory to store context keys values, add as much as you need */
  char* str_lat = (char *) malloc(sizeof(char) * 10);
  char* str_lng = (char *) malloc(sizeof(char) * 10);
  /* Saves as char the coordinates */
  sprintf(str_lat, "%f", latitude);
  sprintf(str_lng, "%f", longitude);
  char* context = (char *) malloc(sizeof(char) * 30);
  ubidots.addContext("lat", str_lat);
  ubidots.addContext("lng", str_lng);
  /* Builds the context with GPS coordinates to send to Ubidots */
  /* Sends the position */
  ubidots.add("position", value, context); // Change for your variable name
  if(bufferSent){
  /* frees memory */
  free(str_lat);
  free(str_lng);
  free(context);
  delay(5000);
Following the below steps you'll be able to retrieve data from Ubidots using HTTP or TCP.
IMPORTANT NOTE: UDP Protocol does not support retrieving data since this protocol is only meant to forward messages from client to server.
Step 4: Uncomment line 33 if you want to see debug messages on the serial monitor.
Step 5: Enter Device and Variable Label on line 38 to retrieve last value from.
// This example retrieves last value of variable from the Ubidots API.
#ifndef TOKEN
#endif
  /* Obtains last value values using. */
  float value = ubidots.get("weather-station", "temperature");
  if(value!=ERROR_VALUE){
    Serial.print("value:");
    Serial.println(value);
  delay(5000);
7.1. Retrieve multiple variable last values over TCP
Following the below steps you'll be able to retrieve multiple last variable valuie from Ubidots over TCP.
Step 3: Uncomment line 33 if you want to see debug messages on the serial monitor.
Step 4: Enter Device and Variable Labels on lines 38 and 39 respectively to retrieve last values from. Note that Variable labels must be in a comma-separated list format
Step 5: Verify the code.
Step 6: Flash the code to your Particle devices.
Step 7: Check your Ubidots account.
Important note: In order to avoid memory overflow issues, we do recommend adding up to 20 variable labels.
// using TCP protocol.
#ifndef UBIDOTS_TOKEN
#define UBIDOTS_TOKEN "" // Put here your Ubidots TOKEN
#endif
Ubidots ubidots(UBIDOTS_TOKEN, UBI_TCP);
/* Obtain multiple last values from a comma separated variables list */
const char* deviceLabel = "machine1";
const char* variablesList = "var1,var2,var3";
tcpMap myMap = ubidots.getMultipleValues(deviceLabel, variablesList);
/* Access to retrieved values based on the ordered list returned */
float var1_value = myMap[0];
float var2_value = myMap[1];
float var3_value = myMap[2];
if (var1_value != ERROR_VALUE) {
Serial.printf("Value for variable var_1: %f", var1_value);
if (var2_value != ERROR_VALUE) {
Serial.printf("Value for variable var_2: %f", var2_value);
if (var3_value != ERROR_VALUE) {
Serial.printf("Value for variable var_2: %f", var3_value);
delay(5000);
