The NodeMCU Development Kit is based on the ESP8266, and integrates GPIO, PWM, IIC, 1-Wire and ADC into one board.
By following this guide you will be able to POST and GET data to/from Ubidots using the NodeMCU ESP8266 module in just a couple of minutes!
Requiremets
  1. Setting up the Arduino IDE
  4. Summary
  1. To be able to work with the NodeMCU ESP8266 platform in the Arduino IDE, you will need to install the ESP8266 platform using the preconfigured Arduino Board Manager. If you are not familiar with adding a board with the Arduino IDE, refer to this article for additional guidance.
2. With the ESP8266 platform installed, select the ESP8266 device you are working with. In the case, we are working with a “NodeMCU 1.0(ESP12E module)”. To select your board from the Arduino IDE, select Tools > Board NodeMCU 1.0(ESP12E module)”.
3. Download and install the UbidotsMicroESP8266 library. For a detailed explanation of how to install libraries using the Arduino IDE, refer to this guide.
Note: The library will create a new Ubidots device named "ESP8266" receiving the mac address of the ESP8266 as the unique device label. If you desire to assign a different device name and label, please implement the follow lines of code into the setup of your code (no changes are needed in the loop).
  • To change the Device Name:
client.setDataSourceName("New_name");
  • To change the Device label:
client.setDataSourceLabel("New_label");
With the following sample code you will be able to post readings taken from the ANALOG pin A0 of the NodeMCU ESP8266.
1. To post your first value in Ubidots, open the Arduino IDE and paste the sample code below. Once you have pasted the code, you will need to assign your unique Ubidots TOKEN, SSID (WiFi Name) and Password of the available network.
#include "UbidotsMicroESP8266.h"
#define TOKEN  "Your_token_here"  // Put here your Ubidots TOKEN
#define WIFISSID "Your_WiFi_SSID" // Put here your Wi-Fi SSID
#define PASSWORD "Your_WiFi_Password" // Put here your Wi-Fi password
Ubidots client(TOKEN);
void setup(){
    client.wifiConnection(WIFISSID, PASSWORD);
    //client.setDebug(true); // Uncomment this line to set DEBUG on
void loop(){
    float value1 = analogRead(0);
    //float value2 = analogRead(2) // uncomment this line to read the GPIO2 of the ESP8266
    client.add("temperature", value1);
    //client.add("switch", value2); // uncomment this line to send the GPIO2 value to Ubidots
    client.sendAll(true);
    delay(5000);
3. Upload the code into your “NodeMCU 1.0(ESP12E module)”. To do this, choose the "right-arrow" icon beside the "check mark" icon.
NOTE: If no response is seen, try unplugging the NodeMCU and then plugging it again. Make sure the baud rate of the Serial monitor is set to the same one specified in your code 115200.
5. Confirm your data in Ubidots. Now you should see the posted data in your Ubidots account, located the device called "esp8266".
  • Ubidots TOKEN
  • Device Label of the device which contains the variable to want to GET.
  • Variable Label of the variable you want to GET
#define DEVICE  "..."  // Put here your Ubidots device label
#define VARIABLE  "..."  // Put here your Ubidots variable label
#define TOKEN  "..."  // Put here your Ubidots TOKEN
#define WIFISSID "..." // Put here your Wi-Fi SSID
#define PASSWORD "..." // Put here your Wi-Fi password
    pinMode(LED_BUILTIN, OUTPUT);
    digitalWrite(LED_BUILTIN, 1);
    float value = client.getValueWithDevice(DEVICE, VARIABLE);
    if (value != ERROR_VALUE){
      Serial.print(F("value obtained: "));
      Serial.println(value);
    }else{
      Serial.println(F("Error getting value"));
4. Summary
With this simple tutorial you are able to POST & GET data to/from Ubidots with the ease of the Arduino IDE and an NodeMCU ESP8266. If your wish to find more examples to handle context or timestamp values in your request checkout Ubidots documentation with the ESP8266 by clicking here
